Dymo DiscPainter Template Dimensions for AudioLabel
Postby tat » Wed Dec 10, 2014 10:01 pm
Will a Dymo DiscPrinter work with AudioLabel?
tat
Re: Dymo DiscPainter Template
Postby Admin » Thu Dec 11, 2014 10:25 am
*** Update 2-14-2015 - The "Dymo DiscPainter" template is now included with AudioLabel Version 6.0 (Build 4)
Yes, AudioLabel works with the Dymo DiscPainter; however, you will need to create a custom template.
To do this:
1. Start AudioLabel and click the "Change Label Template" button.
2. Under the "Disc Labels - CD Printers" section, click the "Create New" button.
3. Type "Dymo DiscPainter" in the "Name" textbox, set the "Units" to "Millimeters", and set the "Paper Size" to "CD/DVD Printer".
4. Now set the dimension as follows:
Left: 0.0mm
Top: 0.0mm
Outer Diameter: 116.0mm
Inner Diameter: 24.0mm or 41.00mm (depending on the hole size of your printable disc)
5. Click the "Save" button, and make sure the "Dymo DiscPainter" template is selected.
6. When you go to "Print", please make sure all of the print driver setting are correct.
We will be adding the official template for the Dymo DiscPainter in the next release of AudioLabel.
Re: Dymo DiscPainter Template Dimensions for AudioLabel
Postby Admin » Sat Feb 14, 2015 9:05 am
The "Dymo DiscPainter" template is now included with AudioLabel Version 6.0 (Build 4) so there is no need to make a custom template as described above.
