Direct to disc tray template for Canon TS9560
Postby mcgheer » Fri Sep 09, 2022 9:51 pm
Hi, does anyone know what canon disc tray template to use with a Canon TS9560.
mcgheer
Re: Direct to disc tray template for Canon TS9560
Postby hickeyt » Sat Aug 26, 2023 2:06 pm
This is probably too late but I had the same problem with a Canon TS 9520.
I posted on this forum and no response. I also contracted support but either this place is out of business or technical support is non-existent since also no response.
I was able to get it to work by modifying a template. It took a lot of blank CDs and ink, but here are the template settings that worked for me:
Template: Canon All Models Tray M - Print Directly on CD
Top: 1.8mm
Left: 2.0mm
Outer Diameter: 117mm
Inner Diameter: 31.8mm
Hope that helps or maybe someone else can use.
hickeyt
