by
» Sun Apr 09, 2017 9:36 am
Hi Kay,
The fading when printing is most likely due to your printer ink cartridge. AudioLabel sends to the label design to your printer in digital format, so what you see in the AudioLabel "Print Preview" is exactly what is sent to the printer. The printer is what responsible for reproducing the image.
So regardless if you use Windows 7 or Windows 10, the same problem with occur if you're using the same printer.
You were correct in trying to run the printer ink cartridge "cleaning" program; however, that does not always fix the problem. Sometimes ink cartridges cannot be unclogged if they have sat too long or are too old.
My suggestion would be to install a new ink cartridge for your printer (or try using a different printer if possible).
