Will not print to disc, but prints to paper
Postby Alby » Tue Jul 07, 2015 3:47 am
Everytime i want to print a disc, it prints onto paper only. Not sure if its a printer issue, audio label issue, or i am doing something wrong...has anyone got any tips please?
Alby
Re: Won't print disc but prints to paper
Postby Admin » Tue Jul 07, 2015 5:02 pm
If the printer prints to paper instead of the disc, then the print driver settings may need to be set correctly.
1. Make sure you have selected the correct disc template in the "Change Label Template" dialog.
2. When you go to "Print" in AudioLabel, click the "Properties" button, and then the "Print Driver Properties" button under CD Printer Settings. This will open the actual print driver settings. From here you need to set the "Media Type", "Printer Paper Size", and "Paper Source".
If you still have problems, please let us know what model printer you are using.
Re: Will not print to disc, but prints to paper
Postby Alby » Tue Jul 07, 2015 8:57 pm
Hi, a big note of thanks to you...I followed your instructions and it worked. Also your fast reply was most appreciated....regards Alby
Alby
