Staples CD Label Template - Item #12-61400
Postby jimrandall » Mon Nov 03, 2014 11:53 pm
Which template do I use for Staple 12-61400 cd label?
jimrandall
Re: template
Postby Admin » Tue Nov 04, 2014 9:54 am
You can select the "Staples (Letter)" template in the "Change Label Template" dialog of AudioLabel.
Since the Staples 12-61400 is a full faced label, you also have to change the "Inner Diameter" to 17mm. To do this, first select the "Staples (Letter)" template, and then click the "Edit Dimensions" button. From there you can change the "Inner Diameter" to 17mm and click the "Save" button at the top.
