Direct Disc Printing for the Brother DCP-J925DW
Postby Skinge » Sat Dec 19, 2015 5:55 am
I can't print printable CD/DVDs to my Brother DCP-J925DW printer.
Can you please help?
Regards
Greg Skinner
Skinge
Re: PRINTING PROBLEM
Postby Admin » Tue Dec 22, 2015 3:15 pm
Hi Greg,
To print directly on the disc using the Brother DCP-J925DW printer:
1. Start AudioLabel and select the "Brother MFC-J825DW Printer" template in the "Change Label Template" dialog of AudioLabel (the DCP-J925DW and MFC-J825DW printers use the exact same template).
2. Next click the "Print" button in AudioLabel, and then the "Properties" button, and then the "Print Driver Properties" button (under CD Printer Settings). This will open the actual Brother DCP-J925DW CD print driver settings.
3. Please make sure the correct the "Media Type", "Printer Paper Size", and "Paper Source" are set correctly in the print driver.
Please let us know if you get it working...
Re: Direct Disc Printing for the Brother DCP-J925DW
Postby Skinge » Mon Dec 28, 2015 8:56 am
Thanks for your reply.
Have upgraded to Version 6 and following you instructions have fixed the problem.'
Many Thanks
Greg skinner
Skinge
