Increase Spine Dimension on DVD Case Label
Postby videoman » Fri Oct 24, 2014 3:21 pm
You product is great but I have to use DVD cases in my business that hold 8 DVDs and as such the spine is approx 25mm. So can you increase the allowable maximum dimension from the present 17.7mm to say 28mm so that I can print covers that fit in the cases properly and are not short?
videoman
Re: Increase Spine dimension on DVD Case Label
Postby Admin » Sun Oct 26, 2014 9:37 am
You can adjust the DVD case spine width in the "Edit Dimensions" dialog of AudioLabel. The maximum spine width is 50.8mm (or 2 inches).
The spine width limit you are hitting has to do with the paper size. A spine width of 17.7mm is about the limit for Letter sized paper (there is not enough psychical room on the paper to print a larger spine). If you print on A4 paper size, you can get a maximum spine width of about 34mm. If you print on Legal, Ledger, or A3 paper size you can get the full 50.8mm.
I would recommend printing on A4 size paper, and adjusting the spine width to 28mm. You can select the A4 paper size the "Edit Dimensions" dialog.
