Printing 4 page booklet - Gap Between Panels
Postby dnelson » Tue Jul 01, 2014 8:07 am
I am trying to print a 4 page booklet.
Two panels on front and 2 panels on back.
I have card stock with two panels but when I try to print the two panels the template puts a 1/4" space between the panels.
I need them to touch on both sides so I can fold them (4 panel)I don't want or need a space between them.
There is a template that I tried that shows two panels touching but it won't allow the panels to touch.
dnelson
Re: Prining Booklets
Postby Admin » Tue Jul 01, 2014 9:53 pm
You should be able to select a similar template in the "Change Label Template" dialog, and then adjust the dimensions in the "Edit Dimensions" dialog. The dimensions you set in the "Edit Dimensions" dialog should print exactly to scale.
1. Are you trying to create a 4 page booklet for a CD, DVD, or Blu-ray case?
2. What is the exact brand/model of your card stock?
