Properties Toolbar Missing on Trial Version
Postby craig843 » Wed Dec 25, 2013 9:37 am
I downloaded the trial version of AudioLabel and when I tried to change the font on a label I couldn't find the Properties Toolbar. It shows checked under the Toolbars tab but doesn't appear. If I click on Properties Toolbar under the Toolbars tab I can see it appear momentarily. Is this a restriction of the trial version or is it a bug?
craig843
Re: Properties Toolbar On Trial Version
Postby Admin » Fri Dec 27, 2013 12:27 pm
The Properties Toolbar should be visible regardless of the version (Trial or Full version). We have not heard of this problem so far. Which Windows operating system are you using?
All of the toolbars are arranged when you install AudioLabel. If you were to un-install AudioLabel, and then re-install, the problem might be fixed.
Postby craig843 » Fri Dec 27, 2013 4:27 pm
I uninstalled the program and reinstalled it and the toolbars are correct now.
craig843
Postby Admin » Tue Jan 07, 2014 5:04 pm
Excellent!
Thanks for letting us know.
