Windows 10, Windows 8.1,
Windows 8, Windows 7, Vista, XP
Version: 6.00 Build 6
File Size: 7.30 MB
Canon Pixma iP7250 CD Printing Software - CD Tray
Postby Godfrey » Wed Sep 11, 2013 4:00 pm
Tried loading the trial version to print directly onto a canon pixma ip7250 but a printer dialogue opens asking what size paper to use!
There is no option to print directly onto the disc even tho it states that a pixma 7200 has been defaulted.
Does that mean that it is still not possible to print directly onto the disc and that paper has to be used?
Godfrey
Re: Cannon Printers
Postby Godfrey » Wed Sep 11, 2013 4:54 pm
or clarification the software states after changing the label template to reaad Canon ip 7250:-
"you have chosen to print directly on the cd"
then on pressing print it defaults to a page where we entered Disc tray j
but the other boxes state printing is standard on plain paper
and when printing there is a direction to remove the disc tray and it then prints onto paper!!
So looks like the downloaded trial software will not print directly onto disc even though it recognises that we want to print directly onto disc.
Godfrey
Re: Cannon Printers
Postby Admin » Thu Sep 12, 2013 1:44 am
AudioLabel can print directly on discs using the Canon Pixma iP7250. If the printer prints to paper instead of the disc, then the print driver settings may need to be set correctly.
To print directly on the disc using Canon iP7250, open the "Print" dialog in AudioLabel and set the printer and the disc template to the Canon iP7250 as shown below:
When you click the "Printer Properties" button, the "Type", "Source" and "Size" need to be set for the direct disc printing settings as shown below:
When you click the "Print Driver Properties" button for the direct disc printer settings, the same settings should look like:
Once you print, a dialog will pop up saying "You have chosen to print directly on a CD. Please make sure the print driver settings are correct on the next screen". The next screen will show the above "Print Driver Properties" dialog again to verify your settings are correct.
Do you have the same settings when printing directly on the disc using the Canon Pixma ip7250?
Re: Cannon Printers
Postby Godfrey » Thu Sep 12, 2013 2:31 am
Thank you so much and we have successfully printed to disc directly.
Unfortunately the problem was not just getting the settings right but the printer requires the disc tray to be closed before printing rather than starting with it open.
For multiple printing of discs is that going to be necessary for each disc? Ie closing and opening the disc tray and then inserting discs?
Godfrey
Re: Direct Disc Printing with Canon Printers
Postby Admin » Fri Sep 13, 2013 2:24 pm
The process for loading a disc into the printer is a little different for each brand and model of printer. The Canon iP7250 printer manual should have the exact process for loading discs. Unless you have a multiple disc tray loader, the process will most likely be one disc at a time. Please post to the forum if find any more information on the subject.
Re: Canon Pixma iP7250 CD Printing Software - CD Tray
Postby filanat » Mon Jul 01, 2019 3:25 am
I have alternative this program! Can recommend you! Easy for use https://www.ronyasoft.com/products/cd-dvd-label-maker/
filanat
