How to Save a Label as a JPEG or PDF
Postby Anja » Tue Sep 24, 2013 10:04 am
Is it possible to save a label as jpg or pdf?
Anja
Re: Saving label as jpg or pdf?
Postby Admin » Tue Sep 24, 2013 1:41 pm
Hi Anja,
Yes, you can easily save your label as a pdf or jpg. After creating your label, you can select "Save As Image" from the "File" menu in AudioLabel. There you can select the .jpg file type.
However, to get the highest quality, save your image as a PNG file at 600 DPI. Once your label is saved as a PNG, you can convert it to a PDF by using the following website:
http://document.online-convert.com/convert-to-pdf
Postby Anja » Tue Sep 24, 2013 2:26 pm
Hi and thank you for the fast response.
However, there is no option in "file" saying "save as Image". It only says "save as" or "save as Default template"...
What to do?
Thank you!
Anja
Anja
Postby Admin » Tue Sep 24, 2013 6:50 pm
I should have asked what version you are using :)
You must be using an older version of AudioLabel, as 'Save as Image' is available in Version 5.0.
For older versions of AudioLabel, under the 'File' Menu, select the "Export Label to Image File" option. Audiolabel can create Bitmap Files (bmp), JPEG Files (jpg), PNG Files (png), and TIFF Files (tif). Once you create the PNG file, you can create your PDF using the previous instructions.
Postby Anja » Wed Sep 25, 2013 5:18 am
Thanks again. :)
The version I have I downloaded for free - version 3.20...
And it doesn´t have the option you mentioned either.
So I guess I´ll have to choose another way to have my label done.
Thank you :)
Anja
